Android = Aeroforce
whats the lag like?? does the bluetooth send a quick readout or is it delayed? a wired source, ie aeroforce, is instantaneous with readings...... just wondering if regardless whether the kr will work or not, will it be accurate enough (as in recieve data fast enough) to read and trust the log.....?
It's not instantaneous, specially with the $5 dollar scanner. From what I've read, this has to do a lot with the scanner that you're using. the China scanner is only 9800 baud or so.
What happens is that the more gauges that you have in your interface, the slower it will get.
My guess is that if you get a higher baud rate scanner, you will not have this kind of lag.
If anyone is having a hard time finding the torque app in the android market, then this will help you out a little! Get the application "Google Goggles" if you don't have it already, and then once you have it, open it and use that program to take a picture of this bar code:
then it should give you the option to open it in the android market or it might open the app in the android market for you automatically!
Hope this helps some!!!!!
Anyone selling their adaptor thing that works? Cause from what I've read its a hit and miss on the chinesse ones so I thought id ask if any of you wanna get rid of your adaptor if you didn't like it so I don't have to go through the haslte of waiting for something from china
The App for Android is "Torque" and the one from Iphone is called "Rev". Not made by the same person. Ian the guy who made torque is supposed to be chiming in here to help us but.....?
This is kinda BS. How can he advertise the program does something that it doesn't do. Like I said before if it doesn't work for W-body cars what DOES it work for GM wise with the extended PIDs?
