An update on my issues with my GTP
jwjones
So I got 3 codes here...
P0336 Crankshaft Position Sensor A Circuit Range/Performance (I have a new sensor ready to install)
P0301 Cylinder 1 Misfire Detected (Thinking its due to the Crank sensor)
P0122 Throttle Position Sensor/Switch A Circuit Low Input (Bad throttle position sensor?)
Your input if you got any lol, Not serious issue right? just sensors that have gone bad within the 173,000 mile life? lol
I'd say change the crank position and TP sensor and go from there. The cyl 1 misfire could be a fouled plug, bad wire, bad coil, etc...
I replaced my Crank sensor and throttle sensor and today threw another code for the throttle position sensor saying low circuit yada yada yada. what the hell?!? Where the hell else could it be coming from?
I'd look over the wiring and use some electrical cleaner and spray the connections and make sure it's seated in all the way.
