brandonl2000
must be why you were slap OUT of gas today
Coolant elbows can be done with just a 15mm
The lower elbows dont break the front cover does if you aren't careful in removal. Mechanics kept breaking front covers that's why they changed it in 99.My local autozone has the metal ones. What year car do you have? The 97/98 had a tensioner that has the lower elbow cast into it. These can break... That is prob why they mentioned it. There is always markup on parts when you go to a shop. Which is also why if you don't like the price tell them and they will most likely work with you to get the price down. But if you can do the work yourself, it is always cheaper. Keep in mind the plastic elbows do break inside the lower manifold and need pryed out... Good luck
