alternator upgrade
grinditout
Seems that someone discovered that a denso 104210-4360 is a good swap for this car.
Also a 08 up impala swaps
Not sure if this info is new here, but here you go.
11180 -
Looks like it was in a lucerne.
just need the regulator converted.
Info, Might already be out there if someone has the time to look.
these are the oem numbers
20757890
20911162
25764632
Alternators - Pontiac - Grand Prix - 3.8L - 2005 - 2008 - Mechman Alternators
feel free to add to this or take away.
not saying it is right or wrong.
My guess is that mechman determined it was the best to turn up the amperage inside of to 240, also seen some 150 amp alternators for the 08 impala , police duty you know.
It is a Frankenstein thing I ma sure some parts from here some from there,
ACDelco 150 Amp Alternator - New
Part #: 15846253 Line: ACD
No rating value for ACDelco 150 Amp Alternator - New (0)
Check Vehicle Fit
Select a store to see pricing & availability
Search for a store page input 7
City & State or Zip
FIND
When autocomplete results are available use up and down arrows to review and enter to select. Touch device users, explore by touch or with swipe gestures.
Alternator New; 150 Amp (KG4)
New Or Remanufactured: New
Amperage (A): 150 Amp
Pulley Belt Type: Serpentine
SHOW MORE
attachment.php
How hard would it be to fix the regulator? I can think of no circumstance where I wished I had less current, and many where I needed more
I do not know, I am sure, it is all off the shelf stuff.
I will make a few more pictures between now and next week of the Mechman installed.
It is tight.
And I see no numbers on it to give a clue.
