For the brown wire at the switch, can I tap into the brown wire already at the other switch? This appears to just be "key-on" power, correct? Aside from that, I think I have the rest figured out.
Both seats are out and I have the heat pad in the passenger seat. Getting ready to try to finish up the wiring portion.
Here is the wiring on the bottom of the passenger seat, as of now. The green connector has one brown and one black going to it and two browns out of it. I'm not certain where they go, either.
Green connector is to power up the seat back heat, which I didn't know these seats had. Those are tied in now.
I am planning on splicing into the little brown wire at the original switch to go to brown wire on the new switch on the passenger side, unless that's not the right thing to do. Any thoughts on this?
Basically, on the switch, the gray wire and brown wire will tie together on the switches. The blue and red wires will go to the relay and the ground will just tie in with the rest of the grounds.
