Aeroforce??
to the OP, i got that 3 wire connector and removed the jumper and put the red wire to the switched 12V that my other guages are on and now it works great.
Nice :th_thumbsup-wink: It was a huge relief for me when it started working, I thought I screwed up a 250 gauge before i even seen it work lol
If you have an android phone, or iphone, sell the aeroforce, n buy the torque app for $2 or whatever the amount is, and buy a $35 obd2 port bluetooth adapter and there is your $37 scan gauge.
I can't get Torque to show data for KR. Any hints?
Re: Aeroforce?? Help!!!!!
My aeroforce is doing the same thing. It worked fine a couple weeks ago when I tested it in the cigarette lighter. I get my pod I wire it up and it turns on, shows to parameters with no readings then powers off. I can go in the menu and it will stay on, as Soon as I hit scan, it shuts off. I hit either of the two buttons, it's just red.. Help!!
IIRC i connected the middle wire to key on power coming out of my sterio. I have a 96 monte. never had a prob
I have it tapped into the sunroof which is 20amp also. Power is not a problem like I said I can have it in the menu screen forever.. As Aston as I hit scan it shuts off. I tore it apart ounce again and noticed a wire is only holding on bye the casing. It's the black wire on bottom plug, with 8 ports. Which is the one that goes tithe obd2 port I believe. I don't know how to upload a pic from my iPhone on here. Or I would show you guys. Ima try and sauter it.
