DJNight2k
I have a few GM side cover gasket kits for our transmissions. These things are $60-80+ from the dealer. Selling for $35 shipped Send me a pm or email [email protected] if interested. Thanks!
All prices are plus paypal fees.
*TransGo Shift Kit. Brand New, unopened. From TEP. $45 Shipped
*<10k mile factory timing chain and tensioner. (no gears) bought for different build, then decided to go turbo. $15 shipped.
Bead Blasted dogbones, stock length $30 Shipped
NEW GM steel oil pan $50 +shipping
Set of very low mile ratcheting sprags for 4t65e Transmission $65 shipped
Hardened 4th clutch shaft $55 shipped (1 sold, one left...)
GM Engine Sealant RTV - like ZZP sells, new unopened tube $10 shipped. (10+ available)
4t65e Trans Filter in pan - OE filter, NOT an aftermarket one $25 shipped.
OEM GM Valve cover gaskets. Have a few sets, some SC some NA $20 a pair shipped let me know which style you need
I have some other random trans parts and grand prix parts so if you are looking for anything specific lmk. Have some oe clutch kits, wiper park mechanisms, oe front calipers $40/PR +shipping, gray GTP badges $30/pr... may have more. Shoot me offers for now, will update some things with prices as I go
L26 Upper and Lower intake manifold. $OLD
3000 stall converter from Dynotech (built by ProTorque) <10k mile (258mm) 3800 supercharged l67 - No need for drilled flexplate or worries about converter clutch issues! $OLD
WBS Red poly mounts set of round dogbone mounts (BNIB) $OLD
Poly upper motor mounts in brackets (black square ones) $OLD
Intense lightweight pushrods 7.050" $OLD
ARP Main Studs NEW never installed, not in box $OLD
HV3 insert for l36 intake manifold $OLD
HV2 - setup for use in l26 intake $OLD
Front cover with machined oil pump cover (&pump) for rollmaster double chain. $OLD
LS7 lifters, low miles approx 12k IIRC, excellent condition $OLD
Also have 4 NIB LS7 lifters from the GMPerformance 12499225 kit $25 shipped $OLD
Rollmaster double timing chain set 15k on it $OLD
97-03 OE grille inserts new in bag $OLD
Brand new in box Innovative Turbo 54mm compressor wheel with polished E cover(3" in, 2" out). T3 exhaust housing with 5 bolt outlet, .63AR and stage 4 exhaust wheel. Was originally the base turbo for the z7 kit from zzp, bought from Matt (Stattama) but I think I would like to go just a little bigger. Willing to work with trade of precision 6262 or similar 5bolt outlet preferred. $OLD
