    TIPS:
*Added* Shift Kit, 4th shaft, sprags, Oil pan, gaskets, Dogbones, & More!
Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
TTT Finally available.. I can get you a new, just released Sonnax Billet 3rd piston kit. Drop in replacement with 50% more apply area = 200% more clamping force. Will work with stock or zpack or any other setup that works with the OE piston!!
Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
You said you have random trans parts? How much would you need for all the random torrington bearings?
Still have this stuff. any takers?
Just saw ur comment im running a precision 6466 billet , dual ball bearing , .70 ar , S-cover ( 4" inlet , 2.5" outlet i believe ? )
Your pm inbox is full. But I am curious how you modify an HVII to fit in an l26. And will I need longer bolts to install the HVII?
are the poly mounts new or used?
They are used. Bought them already in front mounts then I got the black friday WBS kit with all the mounts so I never ended up using them. They are in very good condition and come already installed in the mount bracket. LMK if you have any other questions or need pics
Weekend bump.. sold pushrods. Added red poly mounts
Re: 3k converter, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet 3rd
TTT Sold mounts in brackets. Still have stuff left! Anyone?
weekend bump. sold trans filters and 4th shaft.. may have one of those left. looking now....
Once again.. weekend bump... anyone need some trans parts etc?
how much for the sonnax?
Re: 3k converter, 4th shaft, sprags, poly mounts, Oil pan, v/c gaskets, Dogbones
Pretty much the same price as you can get it anywhere now. I had a place that had them in stock when they first came out so I posted that in case anyone else wanted to order with me. I would be buying it new, I don't have any preowned ones.
