Abs/traction control sensor
mrlogic1234
My abs/service traction control lights just started coming on last night, and what I've noticed is after I restart the car, it only comes on after I start moving. My question is does that rule out a bad connection/broken wire?
Sent from my Galaxy Note 3
I replaced my wheel bearings and it still had the problem. I found out it was a bad ebcm (electronic brake control module). 1100 from GM. So i went onto cheapabs.com and paid 100 to have it fixed plus the shipping there and back and works like new!
Ok so I found that the wire is broken right at the hub. So does that mean it's a lost cause? I was thinking about saudering in a new wire right there but I'm concerned that it won't hold. This hub was replaced under warranty by GM about a year ago, and it looks like the tech didn't secure the connector or it came loose from the little metal bracket that holds it to the hub. A new hub is $162. What do you guys think?
I'm thinking I might just bite the bullet and get a timken hub with the warranty, and when the pass side goes bad I will just take it up there for a warranty replacement.
Good to know about the cheapabs.com. I'm learning about sensors but if it comes to a module or the ecm,pcm whatever I'm going to be lost lol
