about deleting codes
Spartanzz
So I was looking at getting a pcm with the evap and cat codes deleted. But I was wondering if my 98 gtp would still pass emissions if they dis get deleted ?
No way, no cat and no egr? you dont stand a chance, both are there for emissions. You can try it but i dont think youre getting far. What are your mods? Do you have enough mods for the cat to really effect performance? If your bone stock just leave it be.
Yes you will pass. The readiness tests will still go if the pcm is set up proper. SES unchecked option 3 Non report set. If they are only obd port scanning. If there treadmilling you wont pass. Or if they look
If all they do is check 2 see if your ses light isnt lit then yes you will pass.But any further poking with a visual or exuast test and u r screwed. lol
Well the cat OS clogged and I ant to get a test done soon so j can get a tag for the car. Because right now the cat OS clogged and iv got an evap leak I can't find. So I herd u could just delete then from the computer cuz the place I go to don't do anything with the exhaust and I believe only plugs something into the obd port. So I'm just tryin to make it so I can get a test and tag for it that's for this vehicle lol
