Bluemagic
Ok, finally got the engine swap done and everything is fine but we have a few issues.
Engine swap was a 99 gtp engine and trans going into a 98 gt shell
First the temperature gauge isn't working. Not moving or anything. We bled the system and coolant is full.
Second issue is the temp light comes on when the car is put in anything other that park. I was monitoring coolant temps with my torque app and coolant temp only reached 183. After further inspection the connector on the other side of the cluster has a wire that was torn but reconnected. Could that have an affect?
Third issue, the shifter won't shift without using the shift release lock. Thought that was weird. Any ideas? I'll be searching the forums to find out any info as well.
Thanks guys.
Sent from my HTC One using Tapatalk 2
Thanks guys.
