97-99 eclipse wheels???
twol8uluz
Came across some eclipse wheels for pretty cheap. I've tried looking them up and found they are 16x6 and I believe a +35 offset. How/would these fit ok on my gp? And yes I realize they are a skinny wheel. They are the chrome 5 spoke design btw. But I figured for $50 for wheels and tires with 70% tread.......y not for winter wheels?
IF they are stock eclipse wheels they will most likely NOT work. Most imports have a smaller central hub bore than our cars do. Aftermarkets tend to work, bolt pattern is right, but unless you want to do some machining on the wheels or run a big spacer they will most likely NOT work. :(
Ok, that's all I needed to know. I didn't put the hub bore size into consideration. And yeah, they're stock.
Hmmmmm, that sux.... :-( although I don't know the hub bore size on the actual wheel. I've been tryin to google it but can't find any specs on it.
