On my 95 the sunroof dosen't work. So the other day I had the headliner out to recover it so I figured I would check out the sunroof to see what the problem is. I have power to the relay and switch. When you hit the button to open it you can hear the relays clicking but the rood isn't opening. Then I was tapping on and moving the relay around and the roof opened, but wouldn't close until I guess the relay made worked. So now I know I have power, the motor is good and the switch is good. I think the relay is bad. Unfortunately it is $113 at rockauto. I really don't want to spend $113 unless I have to. Is there any way I can take the relays apart to clean the contacts. Also is it possible to use regular relays in the circuit and wire them up.
