$500 97 Grand Prix GT Repair Progress
So I'm starting to have doubts as to how long I can keep this car from falling apart. I got the bolt rethreaded and used some washers to help tighten it. I still hear what sounds like a tiny air leak coming from either the thermostat or the vacuum line, but the car runs fine. Problem is, now I seem to have a leak back near where I replaced the coolant elbow. Sometimes you can feel water hit you when standing in front of the car, which makes me think it's hitting the serpentine belt. Unfortunately I can't find the leak, though I'm losing fluid again.
My car overheats so much I know it's just a matter of time before something breaks, and I don't think I have the ability to fix whatever the leak is. Taking it to a shop isn't worth it, so right now I'm just putting water in (And trying to be nice by using distilled when I can) every couple times I drive. Despite putting water in, it still gets hot enough that I can smell the engine if I drive for more than 10 or 15 minutes.
It feels slightly moist around a gasket I see that's close to the coolant elbow. It's connected to the big black box above the engine, I think it's the water inlet or something like that? Anyway I can't tell for sure, so I might replace the gasket just to see, but in all honesty I'm not even 100% sure the gasket near the thermostat isn't leaking, even though I don't actually see a leak anywhere.
Looks like I might have to get a car loan and get a car with less problems. Either way I need another car soon, my wife and I both work and have one (commonly broken) car between the two of us.
My Grand Prix has a circulation problem and I can't afford the surgery. Nothing to do now but wait. *Bows head in respect*
I'm just going to use this thread to keep track of how much I spend fixing the $500 97 Grand Prix GT I bought awhile back.
Finished:
Replaced the exhaust hanger so my muffler doesn't scrape against the ground.
-Cost: $4 and a half hour of struggling.
Changed the thermostat and gasket. Old themostat opened too easily.
-Cost: $14, thermostat ($8), gasket ($2), and sealant ($4).
Replaced the front right headlight.
-Cost: $8 for the headlight
Flushed the radiator and replaced the coolant.
-Cost: $14 for Prestone coolant.
-Mechanic's quote: $100
Put in an exhaust connector and a metal strapping kit to fix the exhaust.
-Cost: $6, 1 7/8" exhaust connector ($3), and metal strapping kit ($3)
Cut the engine coolant overflow hose (Don't know the technical name). I accidently hit the hose with a wrench and cracked it. I cut about 2 inches off the hose (Where the crack was) and put it back on.
-Cost: Free
Replaced front and rear brake pads. I was originally quoted $400 to replace front and rear brake pads and rotors, but after taking the wheels off I realized the rotors are fine.
-Cost: $30 for front and read brake pads.
-Mechanic's quote: $400 to replace pads and rotors.
Total: $76
Need To Be Done:
Fix A/C. It blows hot air. Will trying charging it, and if that doesn't help I'll look for leaks.
Replace blower motor resistor. Air only works on max setting
Replace front struts. Not a priority, needs to be done but right now I don't have the time or money, so we'll see.
Replace sway bar. The right end link is broken.
Replaceing that heater resistor is a pain, I remoed my pass seat to make it easyer, youll need a 1/4 socket set. once you get the motor out the resistor is above it against the fire wall held by 3 screws I think, the 2 screws in the back you dont have to take all the way out cause the resistor just slides on tabs, Id say it takes about 30 to 45 min. goodluck. I have some pics of the install if ur intrested...
I like this thread. (suscribed)
But don't get a loan for a new car if your down on money at the moment get a car repair loan and fix whats wrong with the car (way cheaper than buying a car). If you take the car to a shop they will find out whats wrong with it for a fee. Then they will give you a quote to have it fixed. If you cant figure out the problem take it to a shop and have them figure it out or maybe a guy at autozone will be able to figure it out by looking at it and they will probly take a look if you ask. But don't give up just yet and please dont paint your car like that. For me and my friend who (graduated from wyotec for autobody and paint) painted my camaro cost me about 1000.00 just in supplys Paint,tape,paper,sandpaper,bondo,fiberglass and etc... only reason i painted it was because it was a dull purple (i hate purple) and it took a while to do it right easly 5 weeks prepin (on our spare time) but yeah if you want it to look better for 75.00 bucks it won't that way. Personaly buff it and if you want to sand the rust spots go ahead Tape off a square area around the rust spot, sand it, bondo it smooth and napa mixes paint in spray cans to match cars also clear coats im sure if you took your time buffed out your car it would look good again.
O yeah that plug that you are discribing sounds like a fog light plug the light plugs into the plug and then twists into the fog light
If you went to school for autobody you should know that you just can't sand rust away and bondo over it. You have to either sandblast it or chemically treat it, or replace the whole area with new metal. If you sand it and just use body filler(bondo) to go over it, there is still rust there and it will come back. You have to fix it right, otherwise don't paint over it. Infidel.... do you see the coolant puddling anywhere like near your injectors or anyplace on the intake manifold?
Rust Killer FTW
ok so i forgot the part that once you have it sanded don't forget to treat it. I thought that was common knowlage but i guess not to every one good point
good thread.:) i just bought a 99 gtp for $750 which im currently fixing up and restoring. I might make a thread like this when i get alittle more fixed. good luck on the repairs and dont give up hope.
So tonight things took a turn for the worse. I had to drive my wife to work or I wouldn't have driven it at all, but I noticed that there's now a definite leak somewhere. The car also makes a high pitched sound that most would describe as a whistle, but I now it's really my car screaming in pain. When pouring water in the radiator cap, it immediately leaks out. It's dark right now so I can't see for sure, but I'm pretty sure the problem is the water pump. I was planning on getting a new one in the morning, but now I think I have bigger problems.
On my way home (About 5 minutes ago) my temperatures went higher than usual (Because of the fact I have no water, stupid me for driving it). Usually since having my coolant problems my temperatures don't go higher than 200, but a mile from home they started going up to about 240-250 (Near the red). My power steering went, the service engine soon light came on, and the acceleration stopped working. Popped the hood, and my radiator was so hot it was literally glowing red. I poured some water on it to cool it down, waited awhile, and managed to get it home. However I wouldn't be at all suprised damaged the block or head gasket. I know before today the head gasket was ok, but now I'm not so sure. Would I have heard any sounds if the head gasket went?
Also, my temperature gauge did something weird. It went up to about 240, then down to 150, then slowly back up to about 230 again, then down to about 200, then up again. The reason I find this odd is I had no water in it, is this just the pressure building up and then escaping through a leak?
It was so stupid to drive that. The last couple weeks I've been fine filling up with water, driving for awhile, then filling up the next time I drive, mainly because any leak I had was so small that it took hours to drain. Now I obviously have a much bigger leak. I'm going to look at it in the morning, probably take it to a mechanic and see what the damage is.
do you know how hot your radiator would have to be to glow red? You will know if your head gasket went by looking at the oil(if it looks normal that is good, if it looks milky it means that rad fluid is getting in your oil) or the coolant-if it looks normal, that is good. If it looks milky then you are getting oil into your coolant. Short of a pressure test, there is no other way that I know of to tell if your gaskets(be it head, or lower intake manifold) are leaking. DO NOT DRIVE your car until the coolant issue is resolved. Start looking on the exterior to see if you can tell where it is leaking by yourself. If you cant see where it is leaking it could be internal. Do you have any white smoke(coolant smoke) coming from your exhaust when it was full? Not sure why your temp gauge would have done that unless you did have a small amount of water in the line and it periodically cycled through...That would take some more looking into. I know the stock gauge is not fast when it comes to moving temps. My aeroforce responds to temp changes(real time) much faster than my stock dash gauge. We can help you trouble shoot it if you want before you take it into the mechanic but not until you find out if the leak is internal or external. How do you know that you have no water? is it always low? Where do you check it? In the radiator or the overflow tank only? It is possible that your waterpump is shot even if it does not cool your car, but if you know it is leaking, it has to go somewhere.
So I spent all day fixing my car. Bought a new water pump and replaced it, then I noticed the coolant elbow was leaking again, so I adjusted that to stop the leaking, then I noticed the thermostat gasket leaking agin, so I fixed that, then I finally noticed my head gasket is gone (At least I'm pretty sure). The rear of the engine block is leaking a lot of water, and I can't see where it's coming from. Also throwing a misfiring first cyclinder.
Putting it on Craigslist tomorrow. I can't afford to get this fixed, and even if I did who knows what other problems there are now. I wish there was a cheap fix for a head gasket, but even if I get one used I'd have to have a shop mill it down, right? Probably no way to fix it for a couple hundred I'm guessing?
I'm gonna have to accept my dad's offer to loan me money for a new car. I have (had) one car between my wife and I and we both work. After the hell I put the GT through I doubt it's ever going to be reliable again. I still appreciate the 3,000 miles it took me cross country though.
It is probably the lower intake manifold gasket leaking and not the head gasket if your oil and/or coolant looks OK. There is an excellent video on here that is about a half hour that shows you how to do it step by step if you are interested. If you need a link to it, let me know. Otherwise, sad to see it go....I know how much this is eating away at you, but a reliable vehicle is important if it is your only one. Good luck with whatever you choose to do.
on the paint thing, my advice is go to your local ace hardware, order Ospho rust treatment, put it in a spray bottle and soak your rust after you go over it with a wire brush or some 80 grit or heavier, then wipe off excess the next day. Rust is now fixed. Also if you really wanna paint this car go to your local paint shop or napa, get single stage black paint. Its basically spray paint that you put into your spray gun, normally you can get a gallon under 100 and it looks professional if you can operate a spray gun. Also get a gallon of Fiber Strand filler, its very thick an hard to sand but is the best cheap fix to fill rust holes, NOT PROPER OR PERM, but will not fall out like regular filler will. You can do it right and cheap if you know what to use. I do custom paint, and collison and full restos along with my dad who has over 40 years in the field. So any body questions i'm here for ya. Also mym 97 GTP has 215k on the clock and i'm fixing everything. She had more block seal in the cooling system then a parts store carrys in stock, after heads, radiator, egr, water pump, tie rod ends, hub bearings, heater core, and a ton more, i'm still going man. keep your head up, no payment and knowing that you fixed this turd is much better then sayin, hey, check out my new Kia!! just my 2 cents
The oil looks fine as far as I could see, I'm running water instead of coolant right now because of the leak, and it's water that's leaking out. My dad thinks it's a head gasket, do our cars have two head gaskets or one? Like I said, I can't see exactly where the leak is, I just know it's somewhere toward the back of the engine, near the black plastic thing (Which I'm guessing is the intake manifold). If that's the case, I don't know how much that would cost to replace, but if it's not too much I'll definitely fix it instead of selling it. The alternative is selling it and using the money to go toward buying a more expensive (But more reliable) car. My dad offered to give me a loan, since I'm about to buy a house and already have a lot of credit card debt, so a car loan won't help any.
I'm about to go to work, but after I'll take a better look and maybe get a second opinion. It would be awesome if it's something I could fix myself, either by getting a junk yard part or just being able to do it for a hundred or two. From what I've read, the lower intake manifold would be about $40-$80? I'll keep you guys updated on what happens after I find out for sure what the problem is. Thanks for any help.
If it was the head gasket, even running straight water you would still be able to see the diffrence of the oil with water in it. the water doesnt mix with oil it seperates and kinda floats on top would be easily noticable in a drain pan. Like liquifire said id check the intake gaskets first befor diving into a head problem. Good luck
The black plastic thing that is on top of your motor is the intake plenum. That piece sits on top of the lower intake manifold. Under that manifold is a gasket which I believe by your description is what is leaking. Their are two head gaskets on our cars, one between each head and the block. If both the coolant and the oil look OK, it is most likely the LIM gasket....which are quite common to go out on our cars. I will see if I can find the link to the video(it is 33 mins, but very informational.) The video is for a GTP, but you can watch it to get a good idea of what it is. In the video, he takes out the lifters and replaces them, which would not be necessary for you to do. Just set aside some time to watch it and you will have a much better idea of what may have to be done, and may decide to tackle it yourself.
I had my GT overheat once, and about 1 month later the oil and coolant were mixing. I needed the plenum (black plastic housing on top) replaced because it became warped from the overheating. I took it to a shop and it cost me 1200 total, half of which was labor, and one day for them to fix. Probably could of gotten the parts for under 300.
In the two years I've had mine, I've invested in over $5k, which includes an 1100 audio system, and 60k miles. My only regret is that I didnt get a gtp, but now have a solid running car, no car payments and low insurance.
The cost of the car + repairs, and I'm looking at just under 400/month for 24mos.
I could of had new car too, but now hopefully I get another 2 years with minimal maintenance.
You seem to like the car, and mechanically inclined. I'm sure you could fix it up eventually, but it would be a costly hobby. Good luck with whatever you choose.
Well it looks like I'm selling it. I really do like that car, but as I said I need something more reliable. I'm in no rush to sell it, and I may instead buy a car and try to fix this one if time/money allows. Eventually I'll need two cars anyway, since using one car between the wife and I gets hectic. I wish I could keep it if for no other reason than this forums is so great for support and info.
Right now I'l looking between an 02 Mitsubishi Galant with 109k for $2900, and an 02 Kia Spectra with 50k for $2750. There's also a 2000 Ford Focus for $2500 (Don't know milage). For around the same price I also found a sexy 94 Camaro, but I think getting a car that old would give me more problems than the one I already have. Right now I'm just looking for something dependable, and in the mean time I might try to get my GP in decent shape if I can afford to. Budget is around $3000 and I live in Vegas. Any recommendations?
