First post here - so hello all!
I'm rebuilding a 4T65EV/GT transmission in a Volvo S80 (MY2000) and was looking for some assistance with adjusting the clearances for the input clutch pack - I've sorted 2nd and 3rd (both at .050") but the input clutch pack is way off though and adding an extra steel removes all clearance - should I be concerned at the excess clearance? I could remove the clutch material off an old clutch plate and put that in like I did with 3rd...
Also, is it worthwhile increasing the 2nd / 3rd clutch feed orifices in the spacer plate (to say .090”?). I have the Transgo shift kit fitted but may mod the engine later (up to about 320bhp/320lbft).
Finally, I can't stretch to a new torque converter, so I wanted to flush out the one I have and get it as clean as possible. I saw a 'trick' on a US Horsepower/Muscle Car TV program where the guy drilled a small hole on the side the converter to drain the old fluid out and then put in a solid pop rivet to fill the hole - do you guys have any other suggestions? I've put in clean fluid and left it to drain upside down but it's a bit painful...
Cheers,
Chris
Cheers,
Chris
