Thanks everyone.
If i don't go over stock boost levels, i should be fine right? So just don't floor it. ?
I will look for a tuner but it will have to be used (and probably hard to find). So if one doesnt show up for awhile ill just get an overkill or 3800performance pcm.
If i cant get all of these mods on for a month, should i put the 3.8 back on or just drive it below 3/4 throttle?
Thanks
if your going to be looking at getting a dhp powrtuner, you are going to have to get one used as they are discontinued. there is also tunercat, but i dont know much about them and i think theres a hell of a lot more people with pt and hpt that can offer help.
IMO, i would put the 3.8 back on. you COULD just stay out of boost, but since you dont have a boost gauge, you dont really know when your in it. remember that the 3.4 is going to give boost at a lower throttle % than the stock one will. as the pcm is stock, it doest go into PE until 35-45 % (depending on rpm, the lower the rpm the higher the throttle % has to be before going into pe).
pe stands for power enrichment. your pcm will always adjust fuel to run at a 14.7 air fuel ratio (afr). one of the things that happens when the pcm goes into power enrichment mode is the commanded afr is lowered, thus adding fuel. fuel is going to help with kr. so, with boost coming on sooner (and more of it) the pcm still isnt going to add that extra fuel until the throttle position reaches those percentages which you could be seeing ~5 or 6 psi already. which is going to cause kr from being lean. making sense?? these figures may not be exact, im just trying to paint you somewhat of a picture.
what you can do with a tuner is adjust this to lower the TPS to go into pe when you're in boost. this is also done in the other files, but with a tuner you can adjust it custom to your vehicle. like the stock pcm, aftermarket ones are written to be somewhat universal. keeping in mind all weather conditions from the coldest to the hottest and different elevations. custom tunes are always better. also as said above, if you are not comfortable with the tuning idea, maybe a canned pcm would be best for now, and you could go somewhere later and pay for a tune. i was just saying that you could get a "canned file" if you had a powrtuner by downloading the dhp file for free.
