Scottydoggs
Killa Bee
Ive heard the newer style injectors are better anyway![]()
if his 99 harness would only just plug into them.
well he could use the l32 injectors in a pinch...just swap connectors
well as a cheapskate...i wood
I dont know why everyone is making this sound so diffacult. Swap only the engine over, Then swap the fuel rails, Use an adaptor plate so you can run your gt throttlebody. All of the connectors should plug right in. You will be missing the connector for the boost bypass valve but it is useless anyways (I havent had mine since... ever). You will most likely need to use injector adaptors (ev1 to ev6 from racetronics?) or upgrade to 60#s with ev1 connectors. Then have someone come over to flash the pcm. Best bet is a 2001 or 2002 gtp bin file and then use your stock trans settings and maf table and the ve table from the 04 gtp and possibly the timing table as well.
