2000 pontiac gtp
mjb13090
Hi I am new to this forum. I have an issue with my abs system. The abs light ans trac light are both on. I took it a mechanic and he said that a couple different codes came up. He said he didn't know if it was a wiring problem or if everything was actually wrong with it. I was just wonderin if any one else has had this same issue. Any if would be great. Thanks
What were the codes? Possible both front wheel bearings(include sensor) are bad. If they were replaced before you got the car they may have been replaced with cheap ones that only last a year or two. You may also need a pump module but knowing the codes will help with that.
