GrandPrixgtp2000
Re: 1999 gtp icm on firewall
almost done, I started the car today and it ran for about 15 seconds and died, so I took the wires back out and soldered everything. I used 18 gauge wire and
color coded my work, I used red on pins h-p and yellow on pins a-g. I had two white wires on pin A and E, so I had to figure out where they went, I opened up a wiring diagram and Pin E is not used. Pin A is the ignition control so if you do this don't mix them around. I have not fired it up yet because it is 2A.M. so hopefully this after noon it will be all back together and running. I may make a How to Thread on this if you guys want me to.
