19. SENSOR. Distributor (also Knock Sensor)
SENSOR,CR/SHF POSN(4 PIN)(ACDelco #213-151). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (1997-2003) (1999 - 2003). Required: 01
SENSOR,CR/SHF POSN(4 PIN)(ACDelco #213-151). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (2000-2005) (2000 - 2005). Required: 01
23. SENSOR. Distributor (also Knock Sensor)
SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (1997-2003) (1999 - 2003). Required: 01
SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36) (2000-2005) (2000 - 2005). Required: 01
SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: W 3.8K(L36),3.8-1(L67) (2004-2004) (1999 - 2004). Required: 01
SENSOR,CM/SHF POSN(ACDelco #213-346). BOLT-BRACKET-CLIP-CONNECTOR-HARNESS-MAGNET-MODULE-NUT-RETAINER-SEAL-SENSOR-SHIELD-STUD, Distributor (also Knock Sensor). For: WB 3.8K(L36) (1999-2003) (1999 - 2004). Required: 01
