1998 GP GT Alabama
drain bamaged
I bought a 1998 GP GT For $300. it comes with a L67 Not installed but came with the car. it also has the wiring harness and ECU. so it came with the L36 from the factory but the guy threw the bottom end out of it. the car has 285,000 miles on it it needs re painted. the trans has less than 85 thousand on it. did i do good? and what all do i need for the swap. and will the L62 need Premium
a little bout me i am a wounded Iraqi war vet. i am retired as of 2009.
He means L67.
L67 needs 91+
Sure you can swap it in. You'll need a custom tune to run the 4T65e with 3.29's because the PCM that you got will be for a 4T65e- HD with 2.93's.
Sure.
But it will still need a custom tune to run the motor.
L67 and L36 are different, L67 is 8.5:1 and L36 is 9.5:1 compression.
L36 is NA and L67 has a blower.
The L36 pcm wont know what to do with boost and the 2 bar map and among other things.
the l67 pcm has the wrong gear ratio programed into it and needs tuned and the L36 pcm has the wrong motor programmed into it and needs tuned.
You'll have to find someone close by with a tuner or send out your pcm to zzp, intense, overkill, or elsewhere to get it tuned.
