DanPrixGTP
Moderator
Re: 1997 Black GTP, Project Mpg, Step 2 of 4.
Yup just going to replace plugs with XP606 Iridiums and wires with 8.5mm MSD.
Only reason why i choose Iridiums is because i heard they last longer compared to copper. Thats why.
And josh, ill come sometime soon and hook up the AF and get some readings.
Its true. Eridiums people run 50-100k while people recommend replacing copper anywhere from 15-30k
Then AutoZone lies. I had them scan the car, print out a receipt of the codes and it said I could have a bad o2. How do you check for Vac leaks then?
Causes
A code P0171 may mean that one or more of the following has happened:
- The MAF (Mass Air Flow) Sensor is dirty or faulty
Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.- There could be a vacuum leak downstream of the MAF sensor
- Possible cracked vacuum or PCV line/connection
- Faulty or stuck open PCV valve
- Failed or faulty oxygen sensor (bank 1, sensor 1)
- Sticking/plugged or failed fuel injector
- Low fuel pressure (possible plugged/dirty fuel filter!)
- Exhaust leak between engine and first oxygen sensor
This is exactly what new o2 sensor looks like that i just got from zzp last sat. I believe i got a faulty sensor because when my car enters closed loop with the new sensor everything runs really rough. Not saying your o2 is bad but i was wondering about the same thing when i got my new o2 sensor because my old one looks like your old one. i do like the new one better because its fitsStep 2 of 4 done.
Upstream o2 Sensor, and can you say Pain in the as*. The sensor was in a very tight spot and i was crawling all over the engine but finally i managed to get the old out and in with the new. Hopefully this will up my MPG's some.
I hope you don't blow the money on Iridiums. Get the Copper 104's like I told you to. They're $10 and you can replace them once a year. Plugs are the easiest thing EVER to do on a 3800.
No? I ran 104's when I was pretty much stock. That's the next best plug if you're starting to mod. Which he is. I ran 103's after my intercooler XP build. But 104's close to stock.
