Re: 1997 Black GTP, Yet Another Update.
Saturday was an eventful day.
Took a 2.5 hour drive out to Anmar's house to get my car re-tuned.
We fix a vacuum leak I had and worked on his car a bit. Later in the evening we went out to get tuned by Ryan Carter. I have an exhaust leak in my flex pipe, and my Wideband o2 and my upstream o2 are right behind the flex. Like so:
Since there is an exhaust leak right by those two sensors, it's completely scewing up the readings and making my car run quite rich. He said he would tune my car with his own tune made up for it, but I won't notice much difference until the leak is fixed and the fuel tables are cleared, then re-learned.
We went out to tune my car, shift points set at 6k RPM now on the new tune, come to find out at 5500+ RPM my valves float quite bad. With 153k miles on stock valves/valvetrain, the valves must be shot and float like a mother f*cker after 5500 RPM and cause a HUGE spike in KR. On top of that I am getting lots of False KR from bad motor and trans mounts, and one last thing... My spark plugs are bad, after 8k miles. :th_shakinghead2:
With all that together, my car run's like dog sh1t after 5500 Rpm, and it's really hard to get "full" potential of the car without revving high at all. So we backed the shift points back down, lowered Timing again, and the car runs like a pig. Slow as Poo, like always. The only good thing, is it runs just a bit leaner. So basically, I spent $200 on getting a diagnostics of whats wrong with my car.
On the flip side, since my springs are bad, this is a good time to upgrade to 1.9 RR and drop to a 3.4. After all is fixed up, I'm bringing the car back to Ryan and he only charges $50+ for a Re-tune after his tune is already on there. Which is good news.
MY CAR IS PIECE OF POO, END OF STORY.
