1978 Pontiac Firebird Formula-Update- 5/9/2014
Re: 1978 Pontiac Firebird Formula-Update- 3/2/2014
Took off the passenger fender and fender well today to replace with the one from the 79 that I got from the junkyard the other day. I realized how back in the day they made cars to last , it took me 1 hour to locate the 15 bolts this fender was attached to . Here is a pic-
Heading later on today if weather permits to get the new radiator support and radiator I got for $20.
Total spent so far on paint for the underhood , all engine parts that I will need and the purchase of the car is $2050 not bad . :)
you could take the other fender off at this point easy, cause you know where all the bolts are now lol
then take the bumper and rad support off, then clean paint and all that good stuff to the bay, then put the engine in and the body parts last. leaving the front clip off leave lots of extra room to work in, as you can see already with the fender and inner fender well off.
Man !!, that is exactly what im doing lol . I need to take the rad support off to install the new one so im just gonna do what you said . The engine should be in by then end of the month . :)
So went to get the rad. support and radiator and came back with a bumper cover , edelbrock intake and a 750 cfm holley carb that needs rebuild. Im also buying from this guy a set of 6x-4 heads that have been milled with bigger valves which im hoping he will sell for cheap. The heads will help me go from 8.8 cr around 9.1 cr.
More Goodies from RockAuto :)
ACC 235578CUTPILEMB (2355-78:7039:MASS) Carpet
Color: OE Color - Dark Red/ Carmine (7039) $ 156.79 $ 0.00 1 $ 156.79
ACDELCO 3361873A (336-1873A@B111) Starter Motor $ 41.89 $ 16.50 1 $ 58.39
ACDELCO 4SD25X Battery Cable $ 13.90 $ 0.00 1 $ 13.90
ACDELCO 4SD50X (88860078@V10) Battery Cable $ 19.58 $ 0.00 1 $ 19.58
AIRTEX / WELLS 9D1006 (DL6) Door Lock Cylinder $ 11.97 $ 0.00 1 $ 11.97
AIRTEX / WELLS 6T1001 (TL6) Trunk Lock $ 12.10 $ 0.00 1 $ 12.10
DORMAN 77017 Outside Door Handle $ 11.76 $ 0.00 1 $ 11.76
DORMAN 77019 Outside Door Handle $ 11.74 $ 0.00 1 $ 11.74
DORMAN 76910 Window Crank Handle $ 3.43 $ 0.00 2 $ 6.86
DORMAN 77026 Inside Door Handle $ 12.18 $ 0.00 1 $ 12.18
DORMAN 77025 Inside Door Handle $ 12.99 $ 0.00 1 $ 12.99
FAIRCHILD M4071 Weatherstrip Installation Kit $ 10.21 $ 0.00 1 $ 10.21
FAIRCHILD KG2096 Belt Weatherstrip / Window Scraper Seal $ 81.99 $ 0.00 1 $ 81.99
HAYNES 79018 Repair Manual $ 13.89 $ 0.00 1 $ 13.89
KYB 343128 Shock Absorber $ 19.75 $ 0.00 2 $ 39.50
KYB 343131 Shock Absorber $ 20.79 $ 0.00 2 $ 41.58
METRO SB32 (32) Door Stop $ 1.86 $ 0.00 2 $ 3.72
METRO RKB2001105 (2001-105) Weatherstrip Kit $ 108.79 $ 0.00 1 $ 108.79
METRO CS15D (15-D) Cowl Seal $ 5.06 $ 0.00 1 $ 5.06
METRO SB81 (81) Fuel Door Bumper $ 1.09 $ 0.00 1 $ 1.09
METRO SBK210 (210) Hood Bumper $ 17.99 $ 0.00 1 $ 17.99
1973 PONTIAC GRAND AM 6.6L 400cid V8
ACDELCO PF24 Oil Filter $ 3.62 $ 0.00 1 $ 3.62
ACDELCO 3342114 (334-2114) Alternator / Generator
Re: 1978 Pontiac Firebird Formula-Update- 3/4/2014
And probably coming from 30 different warehouses :) oh how I <3 RA!
I should be receiving a total of 8 boxes from RockAuto :) Front suspension kit and Poly body bushings ordered! :)
Poly body bushings will help out a ton I'm sure. Hurry up and get this thing running :D
Re: 1978 Pontiac Firebird Formula-Update- 3/5/2014
Front end off with semi-gloss paint , ready for new suspension components and poly body bushings . Got all my engine stuff in the mail , will start that this weekend. Plan is to finish engine and transmission , drop it in, wire everything correctly and install body panels back on then I will start on the inside > upholstery > paint > glass > moldings > decals then ALL done .
damn you arizona people and your ability to work outside all year long....
ames performance has some nice parts
Well .... yes you are correct all year long! I will be installing misters for the summer lol
Re: 1978 Pontiac Firebird Formula-Update- 4/7/2014
Well I havent posted in a while due to being super busy at work and not having much time to work on the Firebird. Well finally yesterday I took some pics of some progress . I painted all the interior parts , started on some engine work and took some interior pics.
Painted all interior pieces with SEM paint
Got a set of 6x 4 Heads for $160 :)
Inside of car
Engine
