Could I use 130# springs with a stock chain?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
130lbs springs for XP hot is complete overkill... its not a big cam
Not really, that depends on more variables than just the cam.
The XP needs 105s at a minimum. I think the reason most people get away with them is because install height in our cars is usually 1.78 with the retainers we use, not the rated 1.8. That makes the seat pressure a little higher.
To really handle the XP though, 130s are more desirable... especially on higher horsepower builds.
I used to think it didn't really matter... until I saw dyno graphs from various (and my own) setups, showing the 130s helped carry the power a little higher.
So 130# springs with a double roller?
105's will suffice unless you plan on shifting at super high rpms. You may want to consider the s1x cam as well.. Almost the same size as the xp and would probably be more specific to 105 springs due to the better mid-range power.
Easy there... this whole notion that the s1x has better mid-range is a fallacy.
If anything, the XP cam has a wider power band due to the s1x having a tighter LSA.
If I were you do the double roller now. Wether you use the 105s or 130s better to be safe. But get a double roller timing chain installed.
