    TIPS:
1 inch gmr chain
Chevy2709
Looking to buy 1 inch gmr chain looking to run stattama turbo kit on my 2005 impala ss. Even if you know of somebody please lmk thank you.
ha. good luck man. I know about three people on here that would pay top dollar for one
only bet is finding a 15/16" or even a 7/8" chain. alternative is a chain from the ls4 which is only a hardened material chain from the oem IIRC.
Probably better if we had an outboard bearing supporting the turbine shaft/drive sprocket so the full width of the chain took the load instead of only half of it.
....now if only some crazy f***** would actually get around to making it....
I can parts out if the price is good.
The transmission came from gmracing , I have it on my chevy cavalier drag race car but this winter I`m goin to rear wheel drive. the trans have make 60 foot in the 1.32 to 1.40 and I never have problem.
the 4t65 have 3 speed only no overdrive no lock up
transbrake
1 inch chain and 7/16 link not the 3/8 link : cpt701
high hp input shaft : cpt708
torsen differential 4.0 ratio : cpt712
every modification like the gm sport compact performance build book
I think this is the most important part that every one try to find !!!
I also have 3 coan converter 1 : 4000 rpm stall 2 : 4500 rpm stall 3 : 6500 rpm stall
I have the msd shift controler
tell me what part you want and how much your ready to pay for it
Ok I see there a lot of interest for this part
For my complet drag setup 12000$
2 x 4t65e complet refresh and good to go
3 converter coan
1 brand new spare chain
1 torsen gear set
1 set of adapter for 930 cv joint
over 17500 $ in part
1 trans and 1 converter 6500
I will part out only if I find buyer for the good part inside
chain kit 3500
differential 1750
input 650
converter 1250
I know the price is high but these part are very hard to find, dont miss this oportunity
For this shiping at this price I will probably ride myself to your house ... Im good for a big road trip this winter but not to big too
Yes I know but in lest than 1 week I have some good offer so I will try it if not will see later
Tell me how much your ready to spend on the part you want and if I dont received better offer it will be yours
By the way forgive my bad english
