grand2000prixgtp
i am thinking about getting the 1.9 rockers from zzp. i was wondering if i need to get new pushrods or springs also. and will i notice a different when i get them on?
thanks!
thanks!
thanks!
These work with all stock or aftermarket pushrods, lifters, springs, retainers.
alright. is there anyway to change out springs with out taking the head off?
i dont right now i plan on getting a aeroforce gauge some day soon.yes you should get a tune, especially because you already have a zzp tune for the gtp. Do you have a way to scan your KR and A/F ratio?
what is the rope trickOr the old rope trick.
And you don't need to get a tune. But you will notice quite a difference with a tune.
yea ill get all new parts when doing thisYou will want some springs better than stock to prevent valve float on 1.9's or 1.95's. Also make sure to get a new set of valve seals when replacing springs.
You will need to purchase a air/fuel wideband adapter or separate gauge because the aeroforce's do not monitor this stocki dont right now i plan on getting a aeroforce gauge some day soon.
if the cylinder is at TDC the valve cant fall in the cylinder anyway, its just a pain in the ass to turn it over for each cylinder.
