Haven't posted anything in a while; we've been busy between 2 kids, taking the top of the motor apart, and my grandfather passing..
What we've been up to with the GP:
Took the top of the motor apart for LIMs and found that the previous owner had done them semi recently. They were metal felpro gaskets, but went ahead and used the new ACDelco's we bought anyway. There was one spot that looked like it
might have been an issue starting, but don't think they were leaking yet. However, there was still a concerning amount of coolant on the valve cover. Looked a little deeper, and found the coolant bypass gasket was completely destroyed, not sure what happened there..
We also took the front cover off and found the timing cover gasket had failed and was leaking. You can see where the gasket was blown out here.
We also went ahead and threw a new water pump on for good measure since we were in there.
One boot on a vacuum harness was cracked, not sure if it was enough to cause a problem or not, but going to fix that before we get it all back together.
Hopefully, that is all the leaks!
Now to put the gp back together, get it out of the garage, and on to changing the subframe bushings on the Lesabre I am giving my old man. 72k miles, that car should last him a long time!
I am ready for our garage to not have any projects in it, it's been a revolving 3800 shop since January. :th_laugh-lol3:
Though, speaking of projects, I am inheriting my grandfather's 1990 F250. I know nothing about this platform, so this should be a fun restoration. I think it has 400k+ miles on it (real mileage unknown due to max of 99,999 on the odometer, it's rolled at least 4 times though). Most issues are cosmetic, but I am sure the suspension is toast and who knows what we will find when we get in there. My grandfather only fixed things on it if they were completely broken, and only known maintenance was very timely oil changes.
