04+ Suspension
Below Average Joe
Have a clunk after brake change. Not sure what the issue is. I'm thinking of replacing the worn out parts since the car has 120+ on it. Other that the LCA's, sway bushings and tie rod endlinks...what should I replace?
What I did was replace all 4 struts and mounts, both LCA's, the sway bar (With the 97-03 / 06+ Style), both inner and outer tie rods.
-Rob
The sway is good so no need to buy a new one. It is my wifes DD so there is not chance of performance happening, just stock replacement stuff.
Maybe she hot rods it, GP is a race car after all. Whens the clunk happens can you get a general area it comes from and can you repeat the clunk by doing a certain thing like moving the wheel ect. If it wasn't there before you double checked everything you touched right?
Sent from the Milky Way
Clunk only happens when you are on the brakes over a bump with wheel turned right.........caliper has been taken off and inspected on the driver side where I think the sound is coming from. Will be taking apart the passenger side maybe tonight.
