id beg brandon to build one for ya lol worth every dollar.
Anything else i need to add in?
Side note, sounds like the GXP chain is the HV093 Can anyone confirm?
Built 4t65e - The results are in.
I'd pretty much use the list on page 1 minus a few things. You're going with the dual chains vs the single I have spec'd. Aluminum pan... That kind of stuff.
I *believe* the HV093 is the standard replacement chain for all 4T65e's. N/A, SC, V8...
Id totally go single chain if i knew where to find one. TEP says theyre out of production.
this thread here says the GXP chain (which has superseeded the older 4t65e chains as a replacement ) is heat treated and stronger. GXP Chain
So the question is, would the GXP chain support big power as long as im not launching it. If not, any suggestions on how to get my hands on the right chain/sprokets?IIRC, the 7/8" gears/sprockets are stock parts for the older 4T60 (440-T4) and are modified/machined to work in the 4T65e.
...big power...
Although I'm not able to answer that question, the ones who could are going to want a number. What's your version of big power?
Just wondering if anyone remembers the differences for sure.
