04 GT2 Turbo TOTALED!!
Re: 04 grand prix gt2!!
ewww, plastic lim gaskets.
Gotta take care of that, son.
I also think that i've got a cast iron l67 coil pack bracket if you want it you're welcome to it...better than that alummy junker that's prone to cracking.
okay one how do you know its plastic 2 how much you asking for the bracket and 3 how much to get better lim gasket
Your valve covers are bad. That is why there is oil all over the place.
All the 180T stat does is hurt your gas mileage.
how does it hurt gas milage????
and so do i need to replace gaskets on valve covers?
Colder engine gets worse gas mileage than warmer engine. Just google it if you want the technical reasons why.
Yes, they are cheep on Rock Auto so are the metal lim gaskets. Here is a video showing how to replace them, some of the stuff will be slightly different cuz they are working on a GTP but for the most part they are the same. https://www.youtube.com/watch?v=-2ZbFwTNjhg
I honestly can't really tell if they are the plastic ones until the LIM is wiped clean. If the gaskets are black, they're plastic...if gray/silver...then they're aluminum and you're good to go. Durk's right on the VC's, but those are easy to do...and then...you can paint them like you wanted while they are off. For the bracket, hell you can have the damn thing...just let me make sure I didn't toss it when I did the big garage clean out, LOL.
hey thanks blue. so had my first check engine light one whoooooo hooooo..........not :th_thumb-down: turns out though it was jus a simple wire to plug in. I forgot to plug back in the evap system. It was throughing 7 different codes now one is left had it check guy said it was something to do with either my gas door wasnt closed all the way or something to do with the fuel line
polished the tips better so now they look good, i really want to do something on the word pontiac so it stick out
put a screen in to stop all the crap thats coming in and getting clogged in my filter
got most of that out looks better i wouldnt say alot better but it is better forgot to get after pic
okay man i love my car so sweet smoked a monte ss or at least he had the ss badges lmao guy tryed to race me at red light turned green i just wot he pulled away for a secound then i caught passed and dominated him OH YEA
Unless it had the actual Supercharged script on it, they are still L36 cars.
Yeah only 04/05 monte ss' had the l67. I believe it either had to be an intimidator model or one of the poopy NASCAR models.
i think it was the nascar verson. okay so got first check engine light yeaaa..... not >:( feeling like a true gp owner now lol. checked it out guy said it had to do with something like the evaporation system or something or i had a leak some were in my gas line or my gas cap was open. (Last time i got a code like this was my cavalier and its gas cap was broke and didnt close right got new cap fixed it.) so checked my gas cap it was on tight was cleaning around the fuel injectors and and tb was doing some could i have bumped one wrong and caused this code and what can i do to fix it so my light goes off so i dont have to run a scan ever few days just to make sure nothing else is wrong
so that came from a truck got it wired in and everything so excited about it tested it tonight its bright as f*ck. im going to change it to a very bright blue led but if i cant find an led bright enough going to just keep the white its bright enough i could do any work in the dark or just show off the engine nice at night
just got reading your car thread, IMO you can VHT your tails and it can look good, it just takes ALOT of work.
See nice and shiney!
hey i also see you polished your tips looks good thanks for the help and yea i plan on 2k sanding then first coats 2k agian secound coat 3k clear 3k clear 3k clear and then 3k agian and then some seriouse buffing compound and alot of buffing and elbow greas(or just skip the elbow grease and use my grandfathers buffing wheel) and see how that turns out.
finally got my damn check engine light to go off it helps to plug all wires back in when done doing things. about to go clean her out and wash her some super girty
