wrong. I was at 177 wheel horsepower with my N/A set-up which consisted of CAI, 180 Tstat, ubend delete, high flow cat, GT1 cam, #90 springs/retainers, HV3, and high velocity throttle body (keep in mind this is with 20's on)
I did a top swap and I hit 254 wheel horsepower (this is also with 20's on)
so that means I gained 77 wheel horsepower from the top swap.
I know that every car is different but still, thats a ton of power added.
and if you don't believe this I can post pics of the dyno numbers that zzp gave me..it has the N/A setup graph and the top swapped graph on the same sheet showing the before and after.
the ssm90 kit does make good power, but the injector placement is what is the bad part (they are angled differently and apparantly isn't as safe either) everyone has their own opinions im sure, but to me and with my experience a top swap is the way to go.
