'00 Impala LS - 5 Speed and Supercharged
outonthetiles
I've been a member here for a few years so I figure its about time to introduce my car. It's a 2000 Impala LS, which I did a Getrag 284 5 speed swap, LSD, a GenV top swap, XP cam, C5 brakes, HUD, among many other things. Its not a GP, but I think you will be able to appreciate it. This won't really be a build thread because the build has already been underway for a few years. If you want to see the full build thread, hit up the link in my sig. It would take forever to copy all of that over here, but I'll keep you updated with my current projects here.
My current mods are: (updated 6-6-15)
Suspension/Brakes/Chassis
-DNA Lowering Springs
-GMPP Front & Rear Sways
-Poly Sway Bushings
-Boxed Trailing Arms
-Poly Front LCA Bushings
-C5 Corvette Front Calipers
-Braided Stainless Brake Lines
-Olds Alero Rear Calipers
-Hand E-Brake
-EBC Redstuff Pads
-Centric Powerslot Cryo Treated Rotors
-Stitch Welded Strut towers
-Poly engine/trans mounts
-Modified Front Strut Brace
-Rear Strut Brace
-Anti-Pogo Washers
Engine
-L36 Bottom End
-XP Cam
-Crow Cams 105# Valve Springs
-Modified Retainers
-JMB Fenderwell Intake w/ K&N Cone
-Aluminum Oil Pan
-GenV Eaton M90 Supercharger
-Modular Pulley System, 3.5" pulley
-Remote Oil Filter
-00+ Northstar Throttle Body
-H-Body Coil Pack Bracket
-Custom Tune
-Powdercoated/Ceracoated Engine Parts
Exhaust
-'04 SS Factory Dual Exhaust
-Speed Daddy Headers
Cooling
-ZZP Oversized Aluminum Radiator
-9C1 Cooling Fans
-180* T-Stat
-9C1 Power Steering Cooler
Transmission
-Getrag 284
-Spec Stage 3+ Clutch
-EP LSD
-Braided Stainless Clutch Line
Exterior
-Partial Debadge
-SS Spoiler
-Painted Plate Frames
-SLP Grille
-Keyless Passenger Front Door Handle
Lighting
-Yellow Fog Bulbs
-Yellow Hi-Beams
-Silverstar Ultra Low Beams
-Quad Headlight Mod
-ALC Disable Harness
-Surv Switch Mod
Interior
-Head Up Display Retrofit
-SS "Carbon Fiber" Trim
-Monte SS Limited Edition 6 Gauge Cluster
-Triple Gauge Pod A Pillar
-Aeroforce Interceptor
-Glowshift Oil Pressure Gauge
-Glowshift Fuel Pressure Gauge
-NGK AFX Wideband AFM
-Custom Shift Boot
-SLP Camaro Shift Knob
Audio
-Pioneer 6x9's
Electronics
-ZZP S1 Voltage Booster
-Caspers Fuel Pump Rewire
-Hardwired Beltronics 955
-Alternator Rewire
Misc
-A/C Delete
-Aztec Bumper Support
-EGR Delete
-Air Pump Delete
Re: 5 Speed Impala
Thanks! The 284's been holding up real well. It rattles a bit at an idle, not sure why, but other than that it shifts really smooth and takes whatever I can throw at it (the car gets driven hard, real hard).
Re: 5 Speed Impala
Make sure you never miss a gear and booger up a synchro... about the only weak point in the trans.
Re: 5 Speed Impala
Yep, trust me I know. Took me 3 tries to find a good 284 and in the end I sent two of them to Jeff @ EP to make one good trans. I won't be grinding any syncros any time soon.
Re: 5 Speed Impala
Nicely done car! I may not understand why but I do understand how and believe in giving credit where its due. Man, I bet that thing freaks people out! What a blast.
Re: 5 Speed Impala
Love the w-bodies with 5 speed swaps. Makes them so much more fun to drive! Car looks great and still maintains that sleeper look. Looking forward to future pics and videos. I must have missed it. Have you dyno'd or hit up the dragstrip yet?
Re: 5 Speed Impala
When I had my impala on the impala forums I loved this car very nice
Sent from my SAMSUNG-SGH-I747 using Tapatalk
