MissLexx
I was driving my top swapped grand prix gt today and the throttle got stuck wide open, looking back im guessing it got hung up on my floor mat as its happened before. I immediately put it in neutral but must not have gotten it all the way in or maybe i bumped it back idk it happened very fast. It basically was a full rpm neutral drop to drive while moving. It now will not go into any gear as if its stuck in neutral. No grinding unless I go to park and it grinds/clicks a little bit. Im expecting the worse and that my tranny is shot but is it possible that i should be looking for something else that could be the issue? Also if i replace the trans i would just assume to find a 4t65-hd from a gtp, is there any difference in swapping one in other than the tune?
