with 1.95 rockers and stock springs you be floating not flyingunless u keep rpms below 5000
Depending on how the valve floats, you can cause serious damage immediately.
said nobody ever (with a 3800)
You need to float the valve a solid 30 degrees or more at full lift to cause piston impact. These are not hemi heads nor are they anywhere near hitting the piston. You will lose enough power that by the time you are floating bad enough to get 10% of the way to the piston, the motor will just not run.
What about binding on stock springs with high ratio rockers?
ive got hs1.9's and floated like a bit*h at 5500 buddy... now i need a new engine because when you float an intake valve the explosion happening in ur cylinder isnt being contained to the cylinder it is also blowing up ur intake manifoldAnd you have tested this? Or are you just another drive by poster?
seperated lim from charger and warped them both just enough to where no amount of gaskets or sealers will fix the giant vacuum leak![]()
