Problem with elm 327
Timing
So i ordered an elm 327 adapter off amazon and it came with no directions. I need a pairing code and i have tried everything people have mentioned and it wont connect. 0000,1111,1234,6789,5678,9999
Anyone have any ideas or should i return it and get another one?
Make sure it's plugged in all the way and your Bluetooth is on. It recommends GPS on as well.
im trying to connect to it with my bluetooth. Is there a way to connect threw the torque app itself or do i have to connect threw my phone then threw torque once its connected
i have a nexus s 4g
like i can see it when i scan bluetooth devices, it says obd II, but when i try to connect it asks for 4 digit code and ive tried everything people say to use
Yeah, that's the same one I ordered n it was 6789 to connect it. Plug it in, turn on Bluetooth and pair it, n then 6789 was my code, just try all the numbers above. Idk why it wouldn't connect unless its just defected.
from what im reading that most likly the case things have a like 1/3 chance of actually working so you got lucky
do you turn your car on befor or after you try to connect it?
I've done it with both, but at first I did it off. There are LEDs on the elm, get down under n look up n make sure them are lighting up as you plug it in. N also I had to like really plug it in there. Idk if there's a button that snaps in place but mines hard to get out too. So make sure it's in all the way.
alright ya that might be it cus it seemed a little lose but i dont get why it would show up on my phone if it wasnt connected...
Oh yeah, it was showing to pair it..try the disk it came with, i read a review it might tell you some codes in there or how to do it. Also type "how to pair torque app with elm 327" in google and read some reviews.
so it started working randomly with 1234 even though i tried it 5 other times. And then my temp gauge didnt show on cluster untill i shut the car off and turned it back on. And it doesnt seem to read **** besides kr. air fuel doesnt work, fuel pressure, oil pressure.
i read .5% kr at most at wot so far and i have headers, no cat, and egr delete
So you ran through settings but can't pair ? 1234 worked for me then in tourqe make sure settings Bluetooth CBT is selected then get your engine paramters set to what your combo is
Yep that could be it, I forgot you need to set everything up in torque as well. Idk if it'd just read tho thru the ob2 n just read what he's not seeing tho? Does it really matter you think? I haven't been playing with mine too much, nor do I understand too much about scanning either. Just set it up n read a few pulls for kr n compared to others readings myself.
well just thought maybe?? not sure what they do when they dont do what they are supposed to do.. Sounds like you got punked by Amazon. I ordered BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive cuz it had little bit better reviews...I'ld exchange it
well will they send me a return lable or something cus i meen i spent 15 bucks on the thing so it might not even be worth sending back and waiting for the refund i might aswell just buy one and give this to someone
How long ago did you order it? Check your account, they have it set up to print return labels and invoice bar code. You'll see. I just ordered some DCs and had to send them back. Got em WED , printed label ordered different pair, got em FRI and handed the return shoes to UPS. Actually saved 43 cents on second pair, wow.
The BAFX elm327 worked flawlessly
