xwire
alright I know I am a new guy here but I have had this car for my wife for a couple of years and done a lot of stuff to it...
the problem: any kind of positive boost (any thing + on the boost gauge {an AutoMeter boost gauge}) the car acts as it is going VERY lean, you can easy get in to it through the full RPM's but if you try to dip the throttle you get the same results
since I have owned it I have replaced the following:
new long block
ported heads
ported super charger w/ 3.2 pulley
comp cam
pacesetter headers
cat-less back exhaust
new MAF
new Fuel pump
new MAP sensor
new injectors
new 4T65HD trans
ZZPerformance programed ECU
repaired wiring to MAF
new O2 sensor
new ignition control module
the long block came with new:
-----cam and crank sensor
-----crank pulley
and I am sure I am forgetting some things
I know it looks like I have been throwing parts at it but this is not the case, as I have had it I have been making it back to new (my wife and my new born son were riding it it) as I wanted it to be reliable and safe, this problem started before I did the new long block w/ ported heads, ported supercharger, cam, headers and exhaust
I had a previous problem with the MAF and wiring dropping signal sporadicly under boost and cracked three ring lands on the old motor (all though the damn car ran fine like this for over a year after replacing the three plugs with bent electrodes
) this is the reason for the new long block
this problem all started on a long road trip I car was running great (still with the old motor) and I was passing a car on the highway (in it to win it of course) the car kind of stalled and from then on does not want any boost (high load) I am out of ideas and am beating my head against the wall :th_scratchhead:
basically what I am looking for is a brain storming session with anyone putting out idea's I have tried many many things (such as fuel pressure looks good under vacuum and low load, hard to test under boost as the problem) MAF signal looks good
so please please give me your ideas, sorry for the long post
new long block
ported heads
comp cam
pacesetter headers
new MAF
new Fuel pump
new MAP sensor
new injectors
new 4T65HD trans
new O2 sensor
-----crank pulley
