Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
I replaced mine with one from a 98 Monty . It's 1 1/8 thick if I remember . I had to get the Monty lower radiated hose but everything just bolts right in and sensors are swapped fin.
The only down side is that the drain is in a different location and it is a little messier to drain the coolant out
You do know the Monte is the same platform as the GP's, right? All W-bodies. But go with what you need to. I just always figure if it's broken then might as well upgrade when I can if the price is good.
Thanks FordMan, yes knew about W-bodies. Just trying to keep it simple, if I can swap thicker radiator for thin one with no mods, it makes it a no brainer.
