DaytonaGTP500
hey, anyone know of any mock ups or anything anywhere for a duel 255 or 340 fuel pump setup for the gtp? I've been kinda looking around and not seeing anything so I turned here. hope to here something, thanks
Honestly, you will never need dual pumps.
Now what you can do, if you are truly set on added pressure, is do a 255 in tank and a boost a pump outside.
Theres been a few dual pump setups, most copy from other GM platform dual pump setups. Downfall is when one pump fails.
A platform that will never need two pumps? Harsh lol stage 3 heads, l26 intake, st4 turbo cam, s259 72mm turbo, e85 on #80's, a few other goodies we wont mention, and a triple edge trans, was just at zzp two days ago and when I'm done looking for 580+ whp with a good dyno tune.. so yes two fuel pumps sounds right to me.................... but any ways do you know if the f-body setups are in any way close to the setup on ours? because if so I'm sure I can find a mock up from them to base it all off of. thanks guys
In my opinion, the 340 is a huge pile of junk.
Not tryin to argue but Steve at zzp told of a purple one with a really close setup to mine that was maxing out his duel 255 and #80 injectors at 595 whp.... So this is why Im continuously saying duels.... I understand and am totally with ya that a massive 340 sounds like it should more than work but I'm goin by wut zzp is tellin me they've seen on the dyno...Sooo idk
That would be "purpletrtor" or Alex, and one of his pumps failed leaning the hell out of the car but probably didn't blow then because of the ethanol. If you can get a steel tank and sump it, that would probably be the best route and save some money in the end.
Be more specific Paco.
Anyways,
If you are set on duAls.... Then I suggest making a trip to home depot for the parts you'll need to make the setup like I did.
