raverockstar
i took the car out of the shop (fixing intake leak) then i had some trouble turning left.
and i saw a lot of this under the car
It was a mistake. Can't figure how to delete the other one.2 threads?
Raise the car, check the front end. Find the leak and you will know for sure. Since the whole area looks wet, the fluid looks clear and all I see is a film I would say it could be anything.
Power steering fluid is clear going in, but not that way when it leaks out, looks dark like oil.
Oil pans in these cars are know for leaking.
Without checking for sure you can be certain its either something bad or nothing at all. After all wet pavement shows film from other cars oil leaks over time, happens all over the place. Speculation isn't a good thing in this case, you need to know for sure.
That can happen if you overfill the pwr steering reservoir, right? As you turn, fluid is displaced, and pressure builds up, eventually the fluid is being forced past the cap on the reservoir. Check that, as well as the rack and hoses/lines.
This. Im guessing he over filled it and that's whats going on. I would check the level before you pay them do do anything else.That can happen if you overfill the pwr steering reservoir, right? As you turn, fluid is displaced, and pressure builds up, eventually the fluid is being forced past the cap on the reservoir. Check that, as well as the rack and hoses/lines.
