solidsnake1972
Hey guy's is it normal for that purge solenoid (i think that's what it is) making a ticking noise all the time? it the thing that has a black plastic hose and a red plug that plugs into it by the back of the motor.
i never really looked to tell you the truth... but i just looked and it says premium. So would using regular gas cause the misfire problem i had?What does your gas door say?
Did you ever change the plugs and find the top of them damaged?
Thanks for all the info guys, and Plaster rock is in New Brunswick Canada.i can feel the difference right away when im running bad 93 to good 93, ( some stations do have better gas) 87 back to 93 where you belong should make a difference in the cars power.
dont know where plaster rock is but 93 can be that much more then 87, maybe 3 bucks more a tank. after a while you stop looking at the price for 87, as only 93 matters now.:th_winking:
If the car is bone stock as well, I'd recommend at least removing the u-bend...it's a cheap, cheap fix at a local exhaust shop to help kill a bunch of knock.
