gen v support mods
idk if im right but dont u need 04+ heads as well???
Sure dont..L67/L32 have the same heads. I believe the valves are suppose to be a tad bit bigger in the L32..Correct me if in wrong...But not enough to make a noticeable difference or be worth the hassle.
so id basically be fine with a intake then. id get a tune tho prolly send it to someone on here. but all i need would be a tb adapter and lim?
awesome:) gonna do that come tax time
Matt, there are a few threads on here that tell you everything you need to do to pull off the swap. Ive been reading up on them because i hope to be doing this soon too.
L32 has bigger and lighter valves.
They are such a tiny difference you can barely tell.
You'll need to plug the evap hole on the gen V, an egr block off plate will work. Might as well get a n* tb since you have to get an adapter. The gen V 3.8 pulley is like a 3.6 on a gen 3, so whatever supporting mods you'd need for a gen3 w a 3.6 is what you'll want for the gen V. A couple of the gen V bolts are a little longer I think, so make sure you get the gen V bolts.
Switch to coper plugs, even before the conversion, coper is better with the supercharger.
If you stick with the L67 TB, you can keep the Gen V evap and just hook to it instead of your original. Otherwise, I'd put a 90 degree barb in there and run your original evap to that. It's not better, just cleaner IMO than running to the front of the TB.
