but what does that do?
So that means I'm gunna have to buy 2 sets of hids and hope they both work out and aren't some cheap POS'S
What year / trim is your GP?
I have this problem where sometimes when i turn on the lights one or none of the headlights turn on right away. I sometimes have to turn the headlight knob a couple of times to work.
The instructions didn't say which is high/low beam and which one is constant power. I was guessing that the constant power was the middle input on the factory headlamp socket/harness. What type of relay would i need to rewire these HID's, knowing that the instructions call for a 20a fuse.
Yes, you can install a timer that delays power to the headlamps. Most remote starters have a delay-on output for such things. Which starter do you have?
