*** Ultimate HID thread ***
ok....i am having a problem
i just installed this
eBay Motors: DIGITAL SLIM Bi-Xenon Hi/Lo HID Kit H4 9004 9007 H13 (item 220341278966 end time Jan-24-09 00:06:47 PST)
now... my problem is
when i got my high beams on the low beams are really on /////and when i got my low beams on i really got my high beams on
now i did switch the right and left wire on the aftermarket plug and it still do not make a difference so i put it back the way it was so now do i have to switch the wire in the middle some where too??
another thing is where can i get a spacer so i can mount my hids right to my headlight houseing with out have to tape them to it lol i have paypal right now ????????? i have the 9007 bulbs
also how do i know it my kit is the tilted one??
please help me out thanks alot
Most likely, the kit was wired for 9004 specifications. Do you have the instructions where they point out which power wire color goes to where?
I bought my HID kit for $175 and its a 9007 8k and only low beam... I have a 99 Grand Prix.. is this HID low beam really Brighter than a normal high beam? I just hate thinking that there might be a time where i would want to use my high beams and then try to use them and then find out that i dont have any. but...... at the same time so far a havent found a need to go to high beams yet... seems like these are pretty bright as it is.... And are these even legal to have on the car? So far i havent gotten pulled over yet so thats nice...
I didn't want to go through 6 pages LOL
Anyone know the bulb for the EBay Projectors? I have some and were wanting to install HID's. I thought that they were Sylvania Silverstars 9004?
Someone lemme know...thanks...
Don't even bother buying this ebay kits... if its not good quality the ballast are not going to last more than few months. First of all you need to get the wiring harness to hook up right to the battery, after that you need to disable the DTRL
Day Time Running Lights in order for the ballast to get proper power otherwise one will not turn on. I did this on my GTP and still sometimes one will not power on.
okay.....Im picking up an 04 Grand Prix today, want to get an HID kit.....lots of info here.....but what is the "BEST" kit???
all the kits are the same..all of them..
the part that matters is the harness. get a quality harness and everything else will work out fine.
Well after reading and having a few people I know not have good luck with the EBay HID's...I am gonna get some quality ones...
Just need to know what damn bulb came in the projectors since I thought they were 9004's...but I am not sure...
The projectors from ebay ? they use a smaller bulb not the stock one.
Yeah...I know. I pulled it out it just didn't have any indication of which bulb it was on there.
So the stock GTP uses 880 for the fogs and 9007 for the headlights, the ebay projectors uses H1 bulb they are smaller to fit inside the projector housing.
Yeah, the red wire goes to your battery and the black to a ground source ( make sure you scrape the paint well ) but I have hear that if you hook it up to the ground on the battery is better. I don't know what kind of relay you are going to get but mine had 3 10 fuses and one relay. You are going to have to splice into your stock headlight wiring to get the signal for the ballast to turn on.
still trying to find out what kit I should get for my 04 grand prix and for my brothers 06 Dodge Charger..........a link would be great!!!!
Thanks guys
Got em installed, very simple....here a couple before and after pics:
