sirricealot
Right now I have a bad setup, not going to go into too many details.
I realized that I need something better, I miss having my 12" Alpine type R so I decided, I want to get 2 12" Alpine Type-R
My question to all of you, What amp would you suggest? I believe the sub I would be getting is the DVC 4ohm one, so when the voice coils are wired right it should be 2ohm stable subs. I would need a 2 channel amp 2ohm stable that will cover the power of the subs.
I will be most likely getting a box locally from the place I had my head unit installed at, I wanted to get a white box to match my car. Most likely going to be ported.
$$ is an issue, I can't justify spending more than $300 on an amp. I know there are cheaper ones out there, just not too cheap like Lanzar and Pyle lol. Before when I had my single 12" I was running one of the Alpine Vpower amps, but I don't wanna do dual amps.
Thanks
Thanks
