Add gas, brake fluid, coolant, and your wheel speed sensor.
Recorded this video of the engine
WHY?
so i know there is a wobble like noise in there too... but the other noise is what im worried about...
added gas... actually didnt check brake fluid. I added some coolant, but only had a half gallon laying around...
and the wheel speed sensor?! that is what the other lights is saying? thanks
Snout or needle bearings mines making same noise, remove the belt and the noise will go away. Time for a new charger.
Well i'm boned.
this is without any belts.
take a vid with a quick throttle snap, gas it and let off the gas fast. then one of you holding the throttle at say 2,000 -2500 rpms for about 5 seconds, then just let the gas go. aka let off it completely.
dont matter since it makes the noise with or with out them.
im trying to hear if its the bottom end or the valves, broken spring, if it goes away it could be a flex plate.
any milk shake or glitter on the dip stick?
I will get to it when i get done with school today.
My dad still doesnt believe this car needs work.
I hate that about him :banghead:
Yay $500 to play with fans. I am no tuner and don't want to learn. If my car blows up after it gets tune I want to have the opportunity to hit someone.
I would have to drive his HHR... fvck that lolol
