1. Yes, the are actually called "metric" bubble flaring tools. I used
this kit.
2. Yep, I originally got 2 25' rolls. You'll probably want to get 2 rolls as well. You'll need some long lengths, so one 25' roll probably won't cut it. (3/16" line is what you need)
3. No, I did not use a tubing bender. I bent carefully, and I used a few different diameters of pipe for the more aggressive bends.
4. For me, it took about a whole day. Can't honestly say the exact number of hours, but if you set about a day aside, you should be fine. The polyarmor that I used was mild steel, so it flared fairly easily. I've never flared copper line, but I'd imagine the brake like would be somewhat harder than copper. Don't go for the stainless steel hard lines, they require a completely different method of installation than mild steel.
5. Yes, you certainly can. I did this with two jackstands, and a couple of jacks. I only had one side of the car jacked up at a given time, so you might have an even easier time if you get it all off the ground.
6. Can't recall the exact sizes of the fittings, but they'll be for 3/16" brake line. I'd just keep the fittings you take off, and you can match them at an auto parts store later if they appear to need replacement.
This is basically the routing as I remember it:
Master Cylinder---->ABS unit
ABS unit---->"5th" soft line---->front Driver soft line fitting (I thought this was odd and crummy, so I deleted the 5th line and went straight from the ABS unit to the Front Driver wheel soft line fitting).
ABS unit---->passenger side soft line fitting
ABS unit----> proportioning valve----->driver rear soft line fitting
ABS unit----> Proportioning valve----->passenger rear soft line fitting
The proportioning valves simply have a brake fitting on each side, no worries. I just re-used them.
Make sure the Master Cylinder and ABS unit never run dry of fluid. Otherwise they'll need special bleeding procedures that you probably want to avoid. I found that after you take the lines out of the ABS unit, you can take the little rubber boots on the brake bleeder valves (on the calipers) and use them likes plugs in the holes on the ABS unit.
When you're finished and it's time to bleed, make sure you keep that brake fluid reservoir filled up, and be ready to do a lot of bleeding at the calipers... it's gonna take some time to get all the air out.
And please, even though I have no idea why you'd do this, but don't use compression fittings anywhere. Do it right the first time. I know a lot of rednecks that say it's "okay and I don't have any problems" but it's very unsafe. Use the correct flares and fittings.
That's all I can remember atm, just be patient and remember that PB blaster is your friend for getting those fittings apart![/
