Do you run distilled water or water out of the tap in your cars?
Please, I'm made of money.
I have used water from the house (tap) water in the past, never noticed a problem in car cooling systems. Distilled water is better to use because it will reduce the chance of unwanted minerals entering the cooling system.
if the shop is a jiffy lube or such, antifreeze is trucked in in 55 gallon drums, pre mixed most of the time. cant f it up that way.
I'm waiting for him to ask why pure anti-freeze isn't good.
Fact is, pure ant-freeze has freezes quicker than anti-freeze water mix. Also pure anti-freeze doesn't remove heat as well as a mix does.
Water is the coolant. Gylcol is the antifreeze. Other fun stuff is the rust inhibitor. In dexcool/prestone all makes, its oat. In g-05, silicates, asian stuff, phosphates.
Ozarka + Ozarka = Ozarka^2
X + X doesn't equal x^2 it equals 2x.
Matttthhhhhhh lol
And yes in chem it works same way.
1 is in front of everything
For example: the 2 in h2o is subscript
H2O + H2O equals 2H2O
You have two molecules of h2o
if it would be h2o^2 that would mean you have 2 oxygen.
Ozarka + Ozarka = 2Ozarka.
Highschool ftmfw. :p
Matttthhhhhhh lol
Hmm... Maybe I shouldn't have slept through chemistry class in high school lol.
well water is full of minerals. even if its safe to drink.
True,True.But just about everyone who is on well water uses a whole home filtration system now anyway, You should see the crap my water filter catches.lolz. When it comes out its fairly pure.
