Skillet
Here's what the problem is: When I turn the key on start my car when its pitch black out.... The headlights will not come on automatically.... Not even the day time running lights... If I turn on the head light switch, it will turn the night time headlights only, but will not turn on the dash lights or tail lights..... I have even tried covering up the photocell with my finger and it does nothing... After I drive a few miles, wah lah, everything comes on, relay clicks as normal etc..... Sometimes they will kick off going down the highway, sometimes they won't.... I've noticed the drivers information center flickering once in awhile also when this gremlin is around... A few searches have pointed towards the ignition switch, but it shows that you will have air conditioning and blower motor problems also... I have none of these.... Sometimes a month will go by with no problems at all.... I don't understand why the headlight switch won't over ride the photo cell and turn everything on? Other times it will...... I can tell early in the mornings when the problem is going to happen because there is a tell tale sign... When you open the drivers door, the door chime will constantly go off, faster than normal as if the headlights were left on.... and the key is not even in the ignition.... Dealer says its the head light switch..... I hate to spend $185 and not fix the problem..... $185 from napa !..... Car is a 2002 Grand Prix GTP 2 door..
