Changed Spark Plugs, Now I have codes. Please help
GTPJason
I changed spark plugs last night. On the way to work this morning, it ran like crap after it warmed up. Crappy MPG too.
Codes are:
P0300 (multiple misfire)
P0131 (O2 Sensor Bank 1 sensor 1
P0137 (circuit condition O2 Sensor bank 1 sensor 2)
P0171 (fuel trim bank one condition)
I pulled the engine forward to get to the rear plugs. Is there something that is commonly disconnected whild doing this. I've check all the vacuum lines around the s/c and all seem okay.
Any Ideas?
Did you click the wires on all the way? Did you do them one at a time or all at once? You may have crossed a few wires.
It goes on the coils...top to bottom...
6
and if you're standing in front of the motor...
2 4 6
Blower
1 3 5
6
2 4 6
Blower
1 3 5
Thank You! very helpful guys.
I'm thinking maybe I pulled the vacuum line off of the EVAP canister when I rolled the motor forward...:th_wtf:
Whelp, that'd probably do it.
That's for a Bonne' but it's close enough minus our EVAP goes towards the back at the firewall.
Fuel pump was bad. It totally stopped running on me. New pump, all good. Going to do the fuel filter tomorrow. Ohm the injectors and do a compression check just to be sure nothing else is going on.
Thanks for all the help!
Sent from my DROID RAZR using Tapatalk 2
Car has been running good for a couple days now. I have a P0650 code (SES light) I'm assuming someone removed the bulb. Any tips on going in and replacing this?
I did the lim gasket on a girls malibu once and it would randomly not start. Fuel pump went bad sometime while i was working on it apparently. Quite random but easily fixable.
